2 members (RLB, 51 3804),
126
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Hi Everyone,
I am getting ready to pull the V8 out of my first series and put in the straight six. I do not have the two bolts that mount the bell housing to the frame, are these just something I can get at the hardware store or are they something special? Thanks,
Joe
1955 First Series 3100
| | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | I guess you are talking about the bolts between the mounts and the frame or are you asking about between the housing and the mounts? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | What year AD? The mounts changed in 1954 with the new crossmember design. | | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Thanks guys, the truck is a 55 first series and I am talking about the two bolts (one on each side) that connect the bellhousing to the frame of the truck (goes through the big rubber isolator) . Thanks again,
Joe
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I believe the bolt runs up thru the bottom and threads into the bell housing? Hardware store will have a grade 5 bolt that works. You need to determine length thru all the pieces including washers, the thread size and it should be a partially threaded bolt. If it's threaded all the way, It will possibly tear rubber unless there is a sleeve? If its a thru installation with a bolt and nut, same basic as above, size, length, grade. The AD guys will be your best info. Just letting you know that it's not "special".
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It does thread into the bell housing and it is 'special' as it has a pointed end to help line up the holes. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Are you telling him a regular non pointed won't work?
