7 members (Robert Crandall, C10 - C90 Bill, Ponchogl, Otto Skorzeny, 78buckshot, Peggy M, D B Cooper), 129 guests, and 1 robot.
Topics128,089
Posts1,056,144
Members48,436
Hi Everyone,
I am getting ready to pull the V8 out of my first series and put in the straight six. I do not have the two bolts that mount the bell housing to the frame, are these just something I can get at the hardware store or are they something special?
Joe
1955 First Series 3100
I guess you are talking about the bolts between the mounts and the frame or are you asking about between the housing and the mounts?
1951 1 Ton Completed
What year AD? The mounts changed in 1954 with the new crossmember design.
Thanks guys, the truck is a 55 first series and I am talking about the two bolts (one on each side) that connect the bellhousing to the frame of the truck (goes through the big rubber isolator) . Thanks again,
Joe
Sir Searchalot
Sir Searchalot
I believe the bolt runs up thru the bottom and threads into the bell housing? Hardware store will have a grade 5 bolt that works. You need to determine length thru all the pieces including washers, the thread size and it should be a partially threaded bolt. If it's threaded all the way, It will possibly tear rubber unless there is a sleeve?
If its a thru installation with a bolt and nut, same basic as above, size, length, grade.
The AD guys will be your best info. Just letting you know that it's not "special".
It does thread into the bell housing and it is 'special' as it has a pointed end to help line up the holes.
Sir Searchalot
Sir Searchalot
Are you telling him a regular non pointed won't work?
