| | | Forums66 Topics128,081 Posts1,056,069 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 13 New Guy | | New Guy Joined: Aug 2013 Posts: 13 | Installed the windshield and door glass on my 48 delivery today, but ran into a problem that's going to cost a bit!
My passengers door is missing the outer and inner stainless window trim.
Anyone have a source to order these parts from? chris<pixelmonkey>:D | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Chris,
Welcome to Stovebolt.com
1948 Sedan Delivery?
No matter what the model, most likely you will only find stainless window trim used or NOS. Check eBay and try a Parts Wanted Ad in the Swap Meet.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Classicparts.com sells the outers but only in pairs. Not cheap at $160.00 a set Item 19-540. Somebody should have some but still may not be cheap in the Swap Meet, good luck! | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 |
Is the vehicle a sedan delivery? If so, the truck trim will not fit.
- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2013 Posts: 13 New Guy | | New Guy Joined: Aug 2013 Posts: 13 | Chris,
No matter what the model, most likely you will only find stainless window trim used or NOS. Check eBay and try a Parts Wanted Ad in the Swap Meet. thank you for the welcome. friendly board! 48 Panel Delivery with windows. When I first read your reply I was thinking I must have typed sedan or the heat was getting to me. I have my searches setup and fingers crossed. Classicparts.com sells the outers but only in pairs. Not cheap at $160.00 a set Item 19-540. Somebody should have some but still may not be cheap in the Swap Meet, good luck! Thank you for the info! So the total for the inside and outside window trim totals around $360 *stainless outer set and painted inside drivers and passengers* with those numbers in mind, I will keep an eye out for the pass side stainless inner and outer... and if i dont find them after a while *not sure how long*, I'll foot the bill and buy the parts, then list my drivers side stainless inner and outer for sale to recoup some of the cost of the replacement parts. chris<pixelmonkey>:D | | | | | Joined: Aug 2013 Posts: 13 New Guy | | New Guy Joined: Aug 2013 Posts: 13 | great turn out of support from forum members here! i've had a few contact me that have the parts i'm looking for, and have responded with a few questions to each. as for the photos of the windows installed.... Windshield and door glass installed when i first viewed the tinted glass, I was thinking it will need to be a bit darker. After installed, I'm thinking it's great! As for the rectangle side windows, I'm going to weld some 1"x2" .063 metal channel to build the frame for each window. going to be a while before I get to work on that too much. thank you again, everyone! chris<pixelmonkey>:D | | |
