0 members (),
52
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Have just installed the new cylinders in the right rear. Do I really have to start bleeding Hydrovac, then left rear, then right rear ? Shopmanual says so, but my gut feeling says start with the longest distance tube first, meaning right rear first, then left rear. If no air comes from left rear, why bleed the hydrovac ?
How would you do ? My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do it the way the Shop Manual describes.
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | No shortcuts? Crap  I'll just do the same. Startign with Hydrovac, both ports in the right order. Then the left rear, then right rear. My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | With what little time it would take to bleed the wheel cylinders, why not try that 5 minute task first? You should know pretty quick if you still have air by the feel of the pedal!
If that doesn't work then go by the steps laid out in the shop manual! | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | It makes the most sense to bleed the longhest line first. Taking any shortcuts always seem to find their way back to your butt ans snap at you. So forget the book and do it the right way. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Hi,Lastchance! "We" started with the right-rear,on the '59 Viking,BUT,the hydrovac was eliminated. I'd go with '53's advice,and try that first. You may have to bleed the hydrovac,but it seems logical,to bleed the rears first,then the hydrovac. finish with the L.F. wheel. We had to bleed the entire system systematically,several times,before accomplishing satisfactory pedal pressure. Just be patient. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Yes but I had pressure everywhere wnd no air, just changed the right rear cylinders, so I don't think air travel all over the pipes. But we'll see, I will bleed it tonight, caught a nasty cold so haven't been able to proceed. Another thing, how happy do you get when you receive these kinds of mails ? VERY !!  Ulf, Just a verification that parts arrived and its all good? Geoff -------------------------- Alretta Truck Parts, Inc. Bldg.#5B, 2nd floor One Watson Place Framingham, Ma. 01701 Tel# 508-788-9409 Fax# 508-788-9499 Mail to: Alretta Truck Parts, Inc. PO Box 596 Sherborn, Ma. 01770-0596 http://www.alretta.com"Where Parts are a Science and Service is an Art!"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It seems logical (and makes the best sense) to do the bleeding in the order described in the Shop Manual.
I do not know about later brake systems, but I could not get the brakes to feel right on my 54/55 GMC 2-ton with hydrovac when I went through the "regular"/logical non-hydrovac progression. After reading the Shop Manual and going through the procedure described, the brakes were much better. After later using a pressure filler as recommended in the the Shop Manual, the brakes were even better.
| | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | Maybe I'm reading this wrong, but it seems like he just replace one wheel cylinder on the right rear. Just bleed that cylinder and see how things feel.
No need to bleed the whole system if you just replaced on wheel cylinder! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Randy,
If fluid did not drain back to a joint in the lines, you might be OK. A quick bleed and a pedal test would answer your question.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I think if a person were to actually measure the length of the brake line that goes from the hydrovac to each wheel you would see why the shop manual lists the order for each wheel as the length to the front is longer than to the rear. | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Maybe I'm reading this wrong, but it seems like he just replace one wheel cylinder on the right rear. Just bleed that cylinder and see how things feel.
No need to bleed the whole system if you just replaced on wheel cylinder! That's what I've always done. But, only if the master was above the slave cylinders. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | I changed both cylinders at the right rear only. The correct order according to the Shop Manual is: Hydrovac point 1 and 2. Then LEFT REAR, RIGHT REAR, then LEFT FRONT and last RIGHT FRONT. I removed the air on right rear, tested left and hydrovac points and no air anywheere. Still the pedal drops first time, but I haven't adjusted the brakeshoes yet, will do that tomorrow morning. Se the picture from the shop manual below here: http://i185.photobucket.com/albums/x264/uffeg/20130817_175503_zpsfcd15062.jpg My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Having the brake shoes adjusted makes a big difference
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | HOLY CRAP my memory sucks !!! When I changed the master cyl and hydrovac I followed the Shop Manual, saying you should use pressure bleeding. Just rememberd I took the old master cylinder cap and drilled out a hole in it an then took a spare tire, added 20 psi pressure and attached a hose in between. Then I bled all corners and the hydrovac without assistance. http://i185.photobucket.com/albums/x264/uffeg/20130817_215906_zpse8aae998.jpgNow with my memory recovered I will do another attempt tomorrow  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | now there's a tip worth remembering - and worth adding to the Tech Tips  Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I bought a pressure bleeder for my COE and it helps on any vehicle.
A while ago several people posted descriptions of their home-made pressure bleeders.
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | I checked the shoes and adjusted them accordingly. Then bled all around. Breaks are solid like a rock now. I will go to a testcenter this afternoon to see if I have full power on both rear.  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Went to test center. VICTORY IS SWEET !! Brakes are PERFECT  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Aug 2013 Posts: 5 New Guy | | New Guy Joined: Aug 2013 Posts: 5 | I have a 59 chevy Spartan 100, I rebuilt the master and installed a new power booster and three new rubber lines. im having a hard time getting any kind of pedal, where can I find a manual on this truck for bleeding the brakes or some good advise. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Willowbeen, Welcome to the Stovebolt! Did you replace ALL of the steel lines? They rust out from the inside...do you have a small leak in one of them or at a wheel cylinder? Did you adjust the brake shoes? If they are to far away from the drum you have to pump the pedal... Are you bleeding the system in the right order starting at the Hydrovac...do a search here, this has been covered many times. Lastchance towing posted the bleeding order in this very thread...check it out about 8 posts before your's if this link doesn't work. http://s185.photobucket.com/user/uffeg/media/20130817_175503_zpsfcd15062.jpg.htmlThe 1959 Chevy Truck Shop Manual should have all the info you need. Mike B
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | I can scan any page from the Shop Manual if needed. What kind of brakes do you have Willowbeen ?
| | | | | Joined: Aug 2013 Posts: 5 New Guy | | New Guy Joined: Aug 2013 Posts: 5 | I have a 1959 chevy Spartan 100 I have manually bled them and power bled them and I still can push the pedal to the floor, took the rear tires off and drum and I can see the shoes moving some. I replaced all rubber lines and the power booster and rebuilt the master cylinder. the only worries I have is I honed the master out a little and I get some fluid leaking out the boot on the master, not much though. ive been trying to free up the adjusters and so far I can only get 1 to move on the left wheel . there is two wheel cylinders on each wheel. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I don't think you will ever have good brakes with a master cylinder that is leaking any amount of fluid, the adjusters should be free so you can adjust the shoes. Solve those issues and you will have good brakes. | | | | | Joined: Aug 2013 Posts: 5 New Guy | | New Guy Joined: Aug 2013 Posts: 5 | the thing that's unusual is the pedal wont return very fast | | | | | Joined: Aug 2013 Posts: 5 New Guy | | New Guy Joined: Aug 2013 Posts: 5 | I did get three out of the four rear adjusters free and adjusted the rear brakes. how do you adjust the front brakes? | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | willowbeen, MC's are not available for our big TF trucks, but you can send it out and have it sleeved and rebuilt. I've had good luck with Sierra Specialty Automotive, they are very reasonable. Contact Joe Way at [email protected] for more info. Did your pedal return spring break? Mike B
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | The front brakes should have an eccentric adjustment bolt for each shoe on the back of the backing plate at 3 and 9 o'clock. To adjust the passenger side turn the front bolt CCW and the rear bolt CW to tighten the shoe to the drum (reverse the CCW and CW on the drivers side). Jack the wheel up and adjust the front shoe to heavy drag and then back it off to light drag...repeat for the rear shoe. Mike B  | | | | | Joined: Aug 2013 Posts: 5 New Guy | | New Guy Joined: Aug 2013 Posts: 5 | The pedal return spring pulls the pedal back but the master is not coming back too fast. do you think the spring inside the master is broken? Thanks for the MC rebuilding contact and the front adjuster info. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | You probably have so much air in the system it's not acting right. Get the MC rebuilt and start the bleeding process over again. Mike B  | | |
