0 members (), 155 guests, and 4 robots.
Topics128,110
Posts1,056,241
Members48,437
awk
Offline
Hi,
I installed an aftermarket turn signal w/e-flasher on my 54 3100, it 6 volts still. It worked great for about 2 weeks. Now, none of the lights flash when turn on to. The lights light up like they should, but they don't flash. I suspect it to be a bad flasher, is this correct? Why would it only last 2 weeks? It is fused.
awk
awk: 6 volts uses 2 times the current. My best guess is the points in the flasher are burned. Try a 6 volt flasher maybe for an older V.W. if you have a shop in your town that caters to them. If the lights are working there should be enough current to make that flasher work If it won't then the flasher is bad.
Steve H
Oh by the way, 12 volt flasher will flash quite fast with 6 volt lights in the circuit. There is a "bi-metal" strip that warms up and pulls the points apart. More current will heat it up faster. Fuse protects the wire. 6 volt has big wire. so that flasher is the weak link.
Steve H
awk
Offline
Hi Steve,
That for the reply. Yes, when I turn the left or right turn signal on the light light up, but they don't flash. I'm picking up a new 525 flasher today.
awk
awk
Offline
Steve,
Maybe I'm missing something, I am using a 6 Volt Flasher and I do a have a fuse in the circuit. The fuse is obviously good.
awk
Not missing a thing just a bad flasher. Some "kits" come with a 12 volt flasher so I just thought that might be what you have. Let us know if it fixes the problem.
Steve H
awk
Offline
OK, cool. I'll try it tonight. Got a cruise tomorrow night so would like it to work right.
awk
awk
Offline
Steve,
Installed a new 6V flasher last and everything is OK. Just don't know why the other one went out, it was only 2 weeks old.
awk
My best guess? China, no I am not beating a drum here just poor quality control that is all. I am old enough to remember when Japan sent lots and lots of very cheap stuff to here. They got better but they had management that cared. Metallurgy and poor controls are a combination not to be messed with. Points arc, bimetallic strips get hot. Bad materials equal FAIL.
Steve H
Electrical parts are famous in reliability circles for their penchant for infant failures. Testing can fail them, and they offer little or no warning ahead of failure.
I agree with Steve though they don't build them like they used to.
I used to have lots of problems with flashers and then I started buying electronic h.d. Flashers that solved the problem, but they were expensive , but they lasted a long time. Pat
1966 Chevy C 30 1 ton truck
