5 members (Gdads51, TUTS 59, MickeyP, tclederman, 1 invisible), 75 guests, and 1 robot.
Topics128,049
Posts1,055,695
#965609 08/21/2013 8:30 AM
I have a 46 pickup with a dead battery. I "assumed" that I could remove the long side bolt from the battery tray and remove the battery from underneath the truck - no clearance. Am I missing something, or is the only way to remove/replace a deco pickup battery is to remove the floorboards and pull it out from above?
that's why they put that hatch in the floor
i dont know how much it changed from 40 to 41- 46 but the only thing that hatch in the floor allows me to do is check battery levels and access to terminals. i have to remove or lift the floor panel high enough to clear the battery.
huh, don't remember having any problem with my 46 GMC, although it's easiest to have one of those lifting straps that hook over the battery posts .... maybe you have a physically larger than the original standard battery?
i have a standard size six volt. no way the square peg fits in the rectanglular hole.
http://www.oldchevytrucks.com/cart/product.asp?prodid=FL149&i=9881|||||
Mike,
I wonder if an 8v battery would easily fit in that hole? grin
In my 39 the battery cover gives access to only the terminals and cell covers. I have to remove the floor to lift out the battery.
1939 Chevrolet Stake Truck
Thanks everyone - once I tried figured I'd have to remove the floor but wanted confirm. (Was hoping to get it from below - rats).
huh, I suppose the crazy farmer original owner might have enlarged the hole on mine and made a new cover for it, it didn't have those embossed depressions shown on Carters site ohwell
Mike,
i thought of it but you just had to say it yahoo
i tried to remove mine from the bottom but with a revamped tray by PO it only come out from the top. you wont have to take it all the way out. loosen all the floor screws and pick up that side only far enough to get it out.
might be a good time to consider installing a cut off switch,
I had mine on the fire wall in my 52 but high enough where
it was hard to see inside , comes in handy if you need to
boost the battery, you can use the switch instead of having
to open doors, remove floor plate and such.. just a thought
Redryder pix
My Hotrod
