7 members (Maybellene, Hotrod Lincoln, MNSmith, 55shaker, 51sub, Jon G, 1 invisible),
103
Mod | | | Forums66 Topics128,042 Posts1,055,595 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | I have a 46 pickup with a dead battery. I "assumed" that I could remove the long side bolt from the battery tray and remove the battery from underneath the truck - no clearance. Am I missing something, or is the only way to remove/replace a deco pickup battery is to remove the floorboards and pull it out from above? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that's why they put that hatch in the floor
Bill | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | that's why they put that hatch in the floor i dont know how much it changed from 40 to 41- 46 but the only thing that hatch in the floor allows me to do is check battery levels and access to terminals. i have to remove or lift the floor panel high enough to clear the battery. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | huh, don't remember having any problem with my 46 GMC, although it's easiest to have one of those lifting straps that hook over the battery posts .... maybe you have a physically larger than the original standard battery?
Bill | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i have a standard size six volt. no way the square peg fits in the rectanglular hole. http://www.oldchevytrucks.com/cart/product.asp?prodid=FL149&i=9881||||| | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mike, I wonder if an 8v battery would easily fit in that hole? | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | In my 39 the battery cover gives access to only the terminals and cell covers. I have to remove the floor to lift out the battery.
1939 Chevrolet Stake Truck
| | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | Thanks everyone - once I tried figured I'd have to remove the floor but wanted confirm. (Was hoping to get it from below - rats). | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | huh, I suppose the crazy farmer original owner might have enlarged the hole on mine and made a new cover for it, it didn't have those embossed depressions shown on Carters site  Bill | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | Mike, I wonder if an 8v battery would easily fit in that hole?  i thought of it but you just had to say it  i tried to remove mine from the bottom but with a revamped tray by PO it only come out from the top. you wont have to take it all the way out. loosen all the floor screws and pick up that side only far enough to get it out. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | might be a good time to consider installing a cut off switch, I had mine on the fire wall in my 52 but high enough where it was hard to see inside , comes in handy if you need to boost the battery, you can use the switch instead of having to open doors, remove floor plate and such.. just a thought Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
