10 members (sron48, cmayna, Scott, 48jim1ton, frogfarmer, Wayne67vert, Wally / Montana, gswbbc, Gdads51, panel fan), 129 guests, and 0 robots.
Topics128,049
Posts1,055,553
Members48,425
#964439 08/17/2013 9:37 AM
Can someone tell me if a 47-53 4-speed trans bolt up to a 46 bellhousing or are they different? Both trucks have the enclosed driveshaft.
oldburbs #964517 08/17/2013 3:27 PM
The bellhousing from a newer 216 would probably bolt to the older engine, but I'm not sure if the transmission pattern is the same on the original housing or not. I remember some one saying the older transmissions were shorter in length and the enclosed driveshaft is longer on the older trucks than the AD.
oldburbs #964522 08/17/2013 3:39 PM
1948 was the change over year to the SM420 and the bolt pattern is different.
My Blog
oldburbs #964559 08/17/2013 7:24 PM
thanks Dave for the info.
Old Burbs
oldburbs #964889 08/18/2013 9:49 PM
Z
Z Offline
I will do some measuring tomorrow myself. I happen to be trying to get one on a 235 in the prep stage now. Glad you thought of this because I sure didnt.
oldburbs #965080 08/19/2013 3:38 PM
if you have the bellhousing from your 216 engine, it would probably swap on to the 235 engine, so your older 4 spd will bolt up.
oldburbs #965090 08/19/2013 4:20 PM
Sm420's are also longer.
My Blog
