1 members (carbking),
103
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 112 | Can someone tell me if a 47-53 4-speed trans bolt up to a 46 bellhousing or are they different? Both trucks have the enclosed driveshaft. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | The bellhousing from a newer 216 would probably bolt to the older engine, but I'm not sure if the transmission pattern is the same on the original housing or not. I remember some one saying the older transmissions were shorter in length and the enclosed driveshaft is longer on the older trucks than the AD.
John | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1948 was the change over year to the SM420 and the bolt pattern is different.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 112 | thanks Dave for the info. Old Burbs | | | | | Joined: Jul 2013 Posts: 29 New Guy | | New Guy Joined: Jul 2013 Posts: 29 | I will do some measuring tomorrow myself. I happen to be trying to get one on a 235 in the prep stage now. Glad you thought of this because I sure didnt. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | if you have the bellhousing from your 216 engine, it would probably swap on to the 235 engine, so your older 4 spd will bolt up. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
