8 members (1955 1 Series, Rusted Nut, Otto Skorzeny, cmayna, Pre '68 Dave, Gdads51, Joe H, 1 invisible),
97
Mod | | | Forums66 Topics128,192 Posts1,057,251 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 14 New Guy | | New Guy Joined: Jul 2012 Posts: 14 | awhile back I ask about changing the gears in my 1953 3/4 ton because it is geared to low and I lost the information sorry to bring up the topic again. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy jeffw, you can find the info again by looking up your own old post. Right above your question when you are reading it is a header which starts with Forum list, then My Stuff, click on My Stuff, a list will open up, down the list will be Posts, click on that and you will find your old posts. Just click on the appropriate post and it will open up the post and you can view it just like you did before, hope that helps. | | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Well, GM FF 14 bolt rears are cheap($150. here) and plentiful, 3.73, 4.11, ratios.
| | | | | Joined: Jul 2012 Posts: 14 New Guy | | New Guy Joined: Jul 2012 Posts: 14 | yes that helped a lot thank you very much, my 7 year old grandson is doing most of the work and he cant hardly wait to get it going. | | | | | Joined: Jul 2013 Posts: 1 Moderated | | Moderated Joined: Jul 2013 Posts: 1 | Can't bring up ur thread. Bruce | | | | | Joined: Nov 2001 Posts: 23 New Guy | | New Guy Joined: Nov 2001 Posts: 23 | Hi its been a few years since I was on this site and at that time someone told me that a certain year pumpkin out of a automatic would bolt right up to my stock "54" chevy 3/4 ton pickup and I lost all the info can anyone help me out. I would really like to hear myself think or listen to the radio going more then 55 mph sown the Highway | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The 4:10 gear is only going to give you another 5mph, so at 55 or anything more than that your still aren't going to hear much on the radio unless you got it cranked way up.
Denny G
Denny G Sandwich, IL
| | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | You are not going to be happy unless you go to a 3.53 or 3.08.
Patrick has a 3.53 kit.
In all 3 of my 1/2 tons and 1 1 ton this was the first thing I changed out.
If you are planning an engine, transmission and/or tire change plan ahead other wise the juice will not be worth the squeezing. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The gear kit from Patrick's will only work in 1/2 tons. With the 3/4 and 1 ton stock rear, the 4.10 from the '68-'72 3/4 is the highest gear you'll find. Otherwise, a complete rear swap is in order for anything higher. A good source for a 3.55 gear would be to check under Dodge or Ford vans. That gear in a Dana 60 housing is very common, and the overall width is just right for an AD truck. Be aware, though, that many of these are semi float, rather than full float like the originals.
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | ED, GM F14 rear axle entails changing the entire rear axle housing. Dave, the Patrick kit is for a 1/2 ton won't fit the HO52/72 axle. OOp, Bill beat me to it on all fronts, just what I would have posted.
The 4.10 gear is a nice gear for the "stock" 3600. You don't want to be driving that truck 70mph with the stock suspension and brakes, it's not a modern truck with modern suspension. I cruise 55mph much of the time and she's running turning right around 2800rpm. Right around the sweet spot. She will run 60-65 with no problem but then you're getting over 3000rpm and you don't want to run them there for to long. The stock 216 babbett pounder was fine there, when it was new that is, but most are a little to tired to push that hard.
Denny Graham Sandwich, IL
