4 members (Jon G, Gray_Ghost, Bill Hanlon, MRMEROTH11), 85 guests, and 0 robots.
Topics128,068
Posts1,055,881
Members48,428
I found that Autozone is selling distributors for the 58 235 for $60. This is about half of the vendors.
Anyone use one that can comment on the quality?
I bought a distributor at ORielly's for my 250 that was the same brand that Autozone had and it works great so far. I think that the only reason to go to a specialty vender is when the local parts store doesn't carry the part you need. Much of the time, the parts are the same where ever you go.
Gene
1959 Apache
I'm just so used to getting burned on box store parts that even though they are 'perfect fit for your model' they are just for the general series, not the specific truck (clutches was a recent fiasco with 'guaranteed fit'). Plus some parts are just junk.
Will get the dizzy and try it out.
i got mine from there (rebuilt) and it came with pionts, condenser, etc. and so far no problems. chinese ignition coils, not so much.
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Got mine from autozone, 56' 235. No problems at all.
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
Clutches and pressure plates and flywheel bolt-patterns varied much more over the years. Distributors varied very little - basically two styles and two drive gears (53/54 are the years to be careful with). Fit should not be a problem with a 1958 distributor.
"Cheap" is another matter, Materman's post should allay that concern.
Placed order. Beat the 'vendor' cost by at least half.
