1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | took out old rear end and installed a modern rear end. the rear shocks are too short now. the extended length is now 25" with the frame jacked up. need to find a shock that will work. went to two different FLAPS and if its not in the comp. forget it. need help. root 3100 53 | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I found a Monroe shock catalog online that gave the dimensions of their shocks. There maybe other mfg catalogs out there, but onroe was the first I found. Find the shock you want by dimension the cross over to another brand,
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You'll need both the compressed and extended lengths, plus what style ends you need to get the proper fitment.
Bill Burmeister | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Go to ADvance Auto, COMMERCIAL counter and ask them.....and look at the book they have. They DO have the info and most commercial folks can handle it.....just go before 5pm. | | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | they usually stick the commercial parts counter in the BACK where the stock is, most walk-in traffic never even knows they are there (at least that's how it is at my local parts place). | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 |
