1 members (tesa),
142
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 44 | ive slotted a sbc into my 38 pu .also fitted a new aluminum rad to cool the v8.new rad is thicker,purchased from PRC RADS.question,what have u guys with v8 fitted do for a bottom hose.outlet on rad is 1 1/2,inlet on waterpump is 1 3/4 inch
thanx in advance herriot
C MON LETS GO
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | PRC stainless tubes come with the reducing bushings to make it work.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no idea about what's available in Ireland, but auto parts stores here can get rad hose bushing adapters to suit any size difference
Bill | | | | | Joined: Feb 2010 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 44 | i have seen the adapters advertised.im trying to find a hose that will fit
C MON LETS GO
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you just need to find the length needed [use a piece of stiff wire shaped to the space] and get a hose of the larger size [1.75"], then get the adapter to bring one end down as required - likely you'll be getting one of the 'corrugated' flexible type, rather than finding one pre-shaped to your unique application
Bill | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Start here. Then, figure out what length you need. Grab the number. Then find a parts warehouse that will ship to you. Summit Racing, Rock Auto, etc. | | | | | Joined: Feb 2010 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 44 | i found a flexible hose that will do the job advertised.a friend ordered one for his 54 pu with v8.viewed it fitted today said it fitted like a dream so im ordering one tomorrow for my truck.similar to the green stripe one advertised by speedway motors
thanks nunattax
C MON LETS GO
| | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | if you run into this again, I had this problem with my 390 galaxie, I used another hose (about 3 inches worth) as a sleeve inside the larger hose. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Check out my link. Goodyear got smart and started making flexie hoses in multi sizes. | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | check out dayco rad. hose # DL7127M 1 3/4 X 1 1/2 | | | | | Joined: Feb 2010 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 44 | searched that # without success.DL7127M WHERE CAN I GET THAT
C MON LETS GO
| | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | herriot...what I did when trying to get hoses for my 49 was to get coat hangers or a stiff piece of wire and cut those to the lengths you need and bend to the configuration you need as well. also note the sizes of the ends you need....then I went to autozone and the guys at the counter let me go to the back and spend some time with the hoses...for the bottom I ended up buying a much larger hose and cutting just the portion out that I needed....found the bottom hose at autozone and top at o'reillys.....hope this helps................whid 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | i got the hose at auto zone, they had to order, but got in one day don't know about Ireland. ROOT | | |
