3 members (KEVINSKI, Tom McGrath, 59 fleet), 110 guests, and 1 robot.
Topics128,034
Posts1,055,552
#96347 07/15/2006 2:01 PM
My fuel guage stays in the same spot all the time. empty.. It moves when I put the igniton on from dead empty to a hair past empty I feel its the sender unit any ideas. How many gallons is my gas tank. 1954 1/2 ton.. thanks
#96348 07/15/2006 2:39 PM
petmil - you can find a lot of info on how to check to see if it is your gauge or your sender by using the search program above. a lot of good info in their about gas gauges and their problems etc. and how to solve them. not for sure on capacity of tank but i think it is between 12 and 15 gallons. good luck.
PaPa Ed's 54 "Yosemite Sam"
#96349 07/16/2006 3:39 PM
I tried to find that info to no avail. I was under the truck today. I found a fuel filter and a brass looking thing bigger then a fuel filter but the same shape with wires coming out of it. all attached to the fuel line. Whats the brass thing a new type of fuel sender ?????
#96350 07/16/2006 4:22 PM
Riding in the Passing Lane
Remove the wire from the sender. Turn on the ign. Notice the gauge reading. Ground the wire & look at the gauge. It should read full one way & empty the other way. I forgot which on that model. It sounds like you have an electric fuel pump under the truck. Follow the wire going to it & see if it hooks to a switch or to the ign switch. It may be working all the time or just for priming.
1972 Chevy c10 Cheyenne Super
#96351 07/16/2006 4:23 PM
plenty of post on this topic..........do the search deal,,
here is one link
click here
do you have a pix of the object you are speaking of
Redryder pix
My Hotrod
#96352 07/16/2006 4:47 PM
Ok where is the sender wire located I'm new at this but i adapt quicky!!!!
#96353 07/16/2006 5:24 PM
one end will be on the sending unit(top of tank) and it then probably goes under the dash
check out this diagram
click here
Redryder pix
My Hotrod
#96354 07/16/2006 5:44 PM
Joker,
What a great wiring diagram. Very clear and concise. I wonder why it indicates it is for '47-'53 AD trucks, buts lists the tailight lamps as being #1157.
I have been jabbering on another thread about lamps/bulbs, and I recognize this as a 12 volt unit.
Weren't all the AD trucks 6 volt until 1955. Maybe it was a typo on the authors part.
Stuart
#96355 07/16/2006 5:52 PM
dont have the answer,, may have to go to the org. post to find out.........I may look, still waiting for the race to start........
Redryder pix
My Hotrod
#96356 07/16/2006 6:38 PM
Stu,,,,,,,,,here is the org post from GMC248 , looks like chief is the author......
look here and it appears to be 12 volts,, there is a link for the 6 volt in the response also..
later
Redryder pix
My Hotrod
#96357 07/16/2006 7:23 PM
Wow those are great diagrams would my 1954 chevy have fuses???? I'm going under the dash shortly
#96358 07/16/2006 8:54 PM
eek eek
Redryder pix
My Hotrod
#96359 07/16/2006 8:59 PM
Petmil,
I did a search and found this tidbit!
quote:
Originally posted by red58:
Virginia - the AD's didn't have a standard fuse block, hafta make do - the originals just used inline fuses for the add-on accessories -
That's not quite accurate.
On '47 AD's they had a complete fuse panel under the hood with six or eight fuses. By '51 they were using just two fuses under a cover near the regulator. Anything that didn't go through those two used an accessory inline fuse.
This was posted some time ago by Oldsub. I hope it's alright to resurrect it.
Stuart
#96360 07/17/2006 11:30 AM
Petmil,
I think the '54 fuel tank is the same as my '49.. 17 gallons. Catalog says same tank in '47-'E55.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#96361 07/18/2006 8:18 PM
Ok back to my fuel gauge. i did what wrench bender said, took off sender wire it went to full grounded the same wire it went to empty does that mean the sender is ok or broken if it's ok what next here. thanks
#96362 07/18/2006 9:14 PM
Your fuel gauge is good.
Make sure the wire from your gauge to the sender is good - run a new wire, if you are not sure.
Try to run a ground wire from the chassis to one of the screws that holds the sender to your gas tank. If that does not solve the problem, your sender is most likely the problem.
#96363 07/22/2006 3:48 AM
Well I think we have solved my fuel giage problem the float had [censored] in it. I couldn't get a new one but I will, so i soldered the small hole that seem to work. The guage jumps around but at least its not stuck on empty. Thanks for all your help I learned a lot here!!
Peter My pictures below..
http://www.picturetrail.com/gallery/view?p=999&gid=11678687&uid=5951166&members=1
#96364 07/22/2006 7:07 AM
BTW,Pete-the thing near the fuel filter is an electric fuel pump. Good thing to have. If it's wired in through the ignition switch and works,it'll prime your fuel system when you run out of gas or when you don't drive the ruck for an extended time. Or,you could wire it through a toggle switch and only use it for emergencies.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
