4 members (lumbersawyer, Hush, 2 invisible), 64 guests, and 3 robots.
Topics128,026
Posts1,055,407
Members48,422
#962667 08/11/2013 10:20 AM
1955 1st ....235..top is a stud 1/2 "NF20..bottom no stud hole 1/2 " 13..did a stud go in the bottom or a 1/2" bolt????and whats wrong with putting a bolt there..stud might be hard to find...did a search no luck..hope this is the right place for this question...
" STUCK IN THE '50'S "
bolt it
For all practical purposes the stud on the top makes it easier to install the starter. It uses a bolt on the bottom, no stud.
Fred
THANKS
Just took off, inspected, & reinstalled the starter on my '51 project Saturday. The stud on the top side allowed me to "hang" the starter then crawl underneath to put the bolt through the bottom hole. With no stud up top I would have to have held the starter with one hand while I tried pushing a bolt through at the top......and the starter is heavy!!!
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
I understand all of that , thanks, but still would like to know if a stud was original on bottom ....
no, as Fred said above, the bottom was a bolt
