0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | 1955 1st ....235..top is a stud 1/2 "NF20..bottom no stud hole 1/2 " 13..did a stud go in the bottom or a 1/2" bolt????and whats wrong with putting a bolt there..stud might be hard to find...did a search no luck..hope this is the right place for this question...
" STUCK IN THE '50'S "
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | For all practical purposes the stud on the top makes it easier to install the starter. It uses a bolt on the bottom, no stud. Fred
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Just took off, inspected, & reinstalled the starter on my '51 project Saturday. The stud on the top side allowed me to "hang" the starter then crawl underneath to put the bolt through the bottom hole. With no stud up top I would have to have held the starter with one hand while I tried pushing a bolt through at the top......and the starter is heavy!!!
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | I understand all of that , thanks, but still would like to know if a stud was original on bottom ....
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no, as Fred said above, the bottom was a bolt
Bill | | |
