| | | Forums66 Topics128,129 Posts1,056,697 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 22 New Guy | | New Guy Joined: Nov 2011 Posts: 22 | I have started putting the front fenders inner and outer. Having trouble with the fenders the truck was completely apart when purchased .I can not figure out where the lower rear of the fenders bolt to [close to door] .Is there a bracket that they attached to.Any help would be appreciated . Thank you | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | at the bottom of the brace that runs down the back of the fender there's a threaded hole [weld nut in the brace], that should line up with a hole in the bracket off the front of the hinge pillar, need a large flat washer cuz the hole is bigger than the bolt for 'adjustment' allowance
Bill | | | | | Joined: Nov 2011 Posts: 22 New Guy | | New Guy Joined: Nov 2011 Posts: 22 | Red 58 I have welded replacement hinge pillars on both sides .There is only one hole in the pillar and that's in the front facing the engine area. Is there a bracket that bolts to the pillar then goes to the fender , Or does the bolt go through the pillar hole to the fender brace . The original pillars rusted out and not much there . I can drill a hole in them if necessary. Thanks
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 'one hole facing the engine' is likely where the backmost bolt for the door hinge goes - the piece the fender bolts to is part of the pillar bottom, if it's totally gone, you're in trouble, it needs to be properly positioned - it's FFBR55L/R here, it's welded on - for rough idea, see lower right corner this picBill | | | | | Joined: Nov 2011 Posts: 22 New Guy | | New Guy Joined: Nov 2011 Posts: 22 | Thank you red58 that explains the reason for the problem. The lower part of the hinge pillar was completely rusted out so I had nothing to go by .I will buy the parts you mentioned and weld them in. .tanks again | | |
