0 members (),
149
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | Well due to a rocker rod hitting the line it has a good wear mark in the line. Any tricks on replacing this line. I noticed that coolant started to drip when I loosened the fitting in the block end. So I see this line goes through the block to the oil distribution on the other side. Diagram oil line Part I will need What am I soldering?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well cowboy, hate to be the one to tell you this, but if you've disturbed that oil line then you're going to have to replace it from the oil distributor-thru the block-and up to the rocker arm shaft connector. The seal thru the water jacket is made up with compression fittings and once they are disturbed bout the only way to fix it is to replace the whole line.
I think most of us here have made that very same mistake of messing with that line before we discovered how it was installed.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | yes, they are a one time thing, but the good news is they are cheap and easy to replace. Most of the vendors have them, I got one from Jim Carter, and I made another one. It will become apparent what to solder when you do it. However I soldered the other end from what that drawing suggests, as that is how the one I took out was done. It is also apparent it will work both ways. The one I got from Jim Carter was already soldered. | | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | yes getting from Jim Carter. I have no leaks or oil in water or water in oil. just the line has been worn by the rod. not much room in that side panel for much.
seems like a common occurance rod rubbing that oil line. | | |
