| | | Forums66 Topics128,022 Posts1,055,382 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | I have a 283 with stock GM HEI distributor in my '49. The other day it just quit. When I checked there was no spark. So far, I've changes the module, pick-up coil, rotor cap and cover, even the coil in the cap. Luckily, I had almost all of this stuff already, so it didn't cost a whole lot. Another problem is when I put the distributor back in it was about 90 degrees off. I've heard of it being 180 degrees off, but not 90. When I brought number 1 piston up on compression stroke, the rotor was pointed to number 4 spark plug wire instead of number 1. Hope somebody has some ideas. I'm running out of hair!! Thanks
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Did you make sure the coil wire is powered, and it's making a good connection to the distributor?
What is the HEI out of? A 283 never had HEI as factory equipment. | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Yeah, wire going up to the coil is hot. That was the first thing I checked. The HEI is out of a mid 70's Monte Carlo.
| | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | You really didn't need to remove the distributor to change out the parts, but since you did, you just re-installed it out of phase from where you removed it. It can get out of timing any number of degrees by having it a few teeth off or 5-6 and even by rotating the engine with the distributor out of the engine.
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
| | | | | Joined: Apr 2008 Posts: 99 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 99 | Pablos49,
Sounds like you need to re-drop the distributor in with it on #One firing position. Notice how much it turns,(turn it back that much to line up with #One when it's seated) as it drops in. does the distributor shaft drop all the way aligned into the oil pump shaft?
look up a valve adjustment chart for #One and look at the other valves to adjust, they can tell you if your on #One. Small Block Chevy Valve Adjustment Order 0 deg TDC, both number one valves shut. look at the #3 exhaust valve & look at the #5 intake valve, if they are opening; your not on #One. rotate 360.
make sure the wires coming out of the distibutor aren't broken or grounding out. | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | You have to pull the center shaft out of the distributor in order to R&R the pick-up coil.
| | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | I'm starting to think it would just be easier to move the spark plug wires around.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I'm starting to think it would just be easier to move the spark plug wires around. I hope you're not serious. Do it right and get the distributor put in and phased right. | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Update: I finally have spark, but it still won't start. I shot a little (VERY little) shot of starter fluid in the carb yesterday and it tried to start. It looks like I may have a little kink in the rubber fuel line leading up to the pump. I'm going to try getting that out of it today and see if that helps. I have a clear fuel filter on top where I can see it and there doesn't seem to be much in there. I replaced the pump 2 weeks ago, so it shouldn't be that. But I guess I could have gotten a bad one. Oh, by the way. I finally got the distributer set in there right. All the wires are where they should be. Thanks for all the help.
| | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Did you redrop the distributor? If you just moved the wires you risk not getting oil to the crankshaft and burning the bearings. First lesson I learned the hard way many years ago.Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Yeah, I did. Just kept working at it til it finally got in the right place. Found a crimp in the rubber fuel line, so I bent a small piece of steel line to take the place of the crimped area. Still 2 or 3 inches of rubber on both ends of it. Seems to be running good now. I hope. Thanks to all.
