6 members (klhansen, Tom McGrath, Shaffer's1950, David Bush, Hotrod Lincoln, JW51), 82 guests, and 0 robots.
Topics128,051
Posts1,055,735
#96283 07/10/2006 9:59 PM
Does anyone know what color wires are usually used on a generator/Voltage regulator system? I've got two wires coming off of the generator to the regulator, and one big fat one going from the regulator to the ammeter.
Also, what color is usually used from the ammeter to the Starter/Battery?
I'm getting ready to rewire my charging system and I'd like to do it more or less correctly.
#96284 07/10/2006 10:25 PM
Brendan,
Enclosed is a link....I can't believe you don't have this in your favorites list.
http://chevy.tocmp.com/chevywiring/diagrams/1946truckwiring.pdf
Stuart
Actually, Stuart, I do have it...
I just can't read it. grin
According to my Shop Manual, the colors going to the regulator are "Natural Red Tracer" and "Natural Black Tracer".
I'm not using cloth insulated wire on the truck, which severly limits my options for natural-colored wire. grin Is there a modern "Standard" that everyone uses when they use modern wire?
Red from the regulator to guage, Black from guage to battery. That's how the later one are wired, and red wire is almost universally used for the wiring from the alternator on modern cars.
Bill Burmeister
Sweet.
Thanks, Bill.
Do you happen to know what colors are generally used on the Field and Armiture terminals?
From the generator to the voltage regulator:
Blue - Field
Black - Armature
From the voltage regulator to battery/ammeter: Red
Sweet.
Thanks tclederman!
Ok, I'm a little late on that 2nd question.
On the TF's the armeture wire is brown instead of black. Again, modern cars use similar color coding for the wiring to the regulator.
Bill Burmeister
