10 members (sron48, cmayna, Scott, 48jim1ton, frogfarmer, Wayne67vert, Wally / Montana, gswbbc, Gdads51, panel fan),
129
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96283 07/10/2006 9:59 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Does anyone know what color wires are usually used on a generator/Voltage regulator system? I've got two wires coming off of the generator to the regulator, and one big fat one going from the regulator to the ammeter.
Also, what color is usually used from the ammeter to the Starter/Battery?
I'm getting ready to rewire my charging system and I'd like to do it more or less correctly. | | |
#96285 07/11/2006 6:19 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Actually, Stuart, I do have it... I just can't read it. According to my Shop Manual, the colors going to the regulator are "Natural Red Tracer" and "Natural Black Tracer". I'm not using cloth insulated wire on the truck, which severly limits my options for natural-colored wire.  Is there a modern "Standard" that everyone uses when they use modern wire? | | |
#96286 07/12/2006 1:50 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Red from the regulator to guage, Black from guage to battery. That's how the later one are wired, and red wire is almost universally used for the wiring from the alternator on modern cars.
Bill Burmeister | | |
#96287 07/12/2006 4:12 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Sweet.
Thanks, Bill.
Do you happen to know what colors are generally used on the Field and Armiture terminals? | | |
#96288 07/12/2006 1:51 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | From the generator to the voltage regulator: Blue - Field Black - Armature
From the voltage regulator to battery/ammeter: Red | | |
#96289 07/12/2006 5:04 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | | | |
#96290 07/13/2006 2:07 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Ok, I'm a little late on that 2nd question. On the TF's the armeture wire is brown instead of black. Again, modern cars use similar color coding for the wiring to the regulator.
