| | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96253 07/08/2006 10:53 PM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I have a signal stat 900 Sigflare turn signal and I can't find anything on it. I've seen the 800 and 900 diagrams, but my unit has 10 WIRES. Here are the colors: yellow,green,red,blue,grey,grey and black,red and black,white,black,white and green. I think I know where most of them go. Its the white ones that throw me. Cecil........ | | |
#96254 07/08/2006 11:18 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Cecil,
I just looked at Cletis' article in Tech-Tips. Using your VOM and the charts he has layed out, you should be able to dissect this unit.
Stuart | | |
#96255 07/09/2006 2:33 AM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Wish I had kept the diagram and instruction on the one i insalled for a freind. Sorry with out it in my hand I can't help. Here is a tip, If you dont have continiuity tester you can hook up a flash light battery (low voltage) to make things work and test it with a test lamp or volt meter. That way you don't burn stuff up.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
