0 members (), 106 guests, and 0 robots.
Topics128,101
Posts1,056,181
Members48,436
#96253 07/08/2006 10:53 PM
I have a signal stat 900 Sigflare turn signal and I can't find anything on it. I've seen the 800 and 900 diagrams, but my unit has 10 WIRES.
Here are the colors: yellow,green,red,blue,grey,grey and black,red and black,white,black,white and green.
I think I know where most of them go. Its the white ones that throw me. Cecil........
#96254 07/08/2006 11:18 PM
Cecil,
I just looked at Cletis' article in Tech-Tips. Using your VOM and the charts he has layed out, you should be able to dissect this unit.
Stuart
#96255 07/09/2006 2:33 AM
Wish I had kept the diagram and instruction on the one i insalled for a freind. Sorry with out it in my hand I can't help.
Here is a tip, If you dont have continiuity tester you can hook up a flash light battery (low voltage) to make things work and test it with a test lamp or volt meter. That way you don't burn stuff up.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
