6 members (3800GUY, GIJOE298, homer52, Bisbee, Steve_H, Otto Skorzeny), 139 guests, and 2 robots.
Topics128,148
Posts1,056,813
Members48,454
I have some filler around where the mirror attaches. What was used is Everglass.
Hate to have this crack under the bracket. Any experience using this filler
no matter what brand you use, plastic filler is very likely to crack if you bolt things on top of it, it has no structural integrity
they make a metal filler, I think it's called "All Metal", which is probably shavings mixed w/epoxy??
Everglass should be short-strand fiberglass reinforced filler, usually much, much, stronger than the regular filler. Uses fiberglass intead of talc, also it does not absorb water like normal filler.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
is it inside mirror or outside on the door? are you useing it to fill in rust or to hold the screws in place or fill a dent?
The outside drivers mirror. I think the Mirror must have hit something and dented the cowl . So that whole concave portion where the mirror was to go was filled.
Looks like I will relocate down a few inches and forward, without getting into the hood movement and staying on the inside support. That will be all steel.
