| | | Forums66 Topics128,156 Posts1,057,017 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | I have some filler around where the mirror attaches. What was used is Everglass.
Hate to have this crack under the bracket. Any experience using this filler
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no matter what brand you use, plastic filler is very likely to crack if you bolt things on top of it, it has no structural integrity
Bill | | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | they make a metal filler, I think it's called "All Metal", which is probably shavings mixed w/epoxy?? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Everglass should be short-strand fiberglass reinforced filler, usually much, much, stronger than the regular filler. Uses fiberglass intead of talc, also it does not absorb water like normal filler. | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | is it inside mirror or outside on the door? are you useing it to fill in rust or to hold the screws in place or fill a dent? | | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | The outside drivers mirror. I think the Mirror must have hit something and dented the cowl . So that whole concave portion where the mirror was to go was filled.
Looks like I will relocate down a few inches and forward, without getting into the hood movement and staying on the inside support. That will be all steel.
