1 members (tesa), 142 guests, and 2 robots.
Topics128,080
Posts1,055,953
Members48,430
#962336 08/09/2013 8:17 PM
if you had a generator found loose under a hood with tag busted off, how could you tell 6 or 12 v? It's pretty corroded (woods trucks, bought many so they didn't get crushed; If I knew where to sand I might could find some stamped numbers to identify? THANKS, lefty
any numbers would be on the missing tag, and the color of the tag indicates voltage
Belt width didn't change at exactly the same time as 6 to 12 volts but I would suspect wide pulleys as 6 volts and narrow as 12 for a rough visual indicator.
You Tube
Bill,
Is this right:
Black tag - 6v
Red tag - 12v
No additional voltage indicator. Can you tell from anything inside, Bill?
6v through 1955-1st
Chevrolet trucks changed to 12v in 1955-2nd
GMC changed to 12v in 1956
Lefty and Curt,
If you are referring to Chevrolet trucks (vs GMC)
Pre-1953 (37-52?) belt width was 5/8"
1953 onwards was 3/8"(53-62).
yes, red=12V ... there are body length differences, one is longer, but I'm not sure which ... and there will be internal differences a qualified auto electric shop could ID, field winding [the ones attached to the case] resistance is less on 6V than 12V
