| | | Forums66 Topics128,049 Posts1,055,695 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | if you had a generator found loose under a hood with tag busted off, how could you tell 6 or 12 v? It's pretty corroded (woods trucks, bought many so they didn't get crushed; If I knew where to sand I might could find some stamped numbers to identify? THANKS, lefty | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | any numbers would be on the missing tag, and the color of the tag indicates voltage
Bill | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Belt width didn't change at exactly the same time as 6 to 12 volts but I would suspect wide pulleys as 6 volts and narrow as 12 for a rough visual indicator.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bill,
Is this right: Black tag - 6v Red tag - 12v No additional voltage indicator. Can you tell from anything inside, Bill?
6v through 1955-1st Chevrolet trucks changed to 12v in 1955-2nd GMC changed to 12v in 1956
Lefty and Curt,
If you are referring to Chevrolet trucks (vs GMC) Pre-1953 (37-52?) belt width was 5/8" 1953 onwards was 3/8"(53-62).
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, red=12V ... there are body length differences, one is longer, but I'm not sure which ... and there will be internal differences a qualified auto electric shop could ID, field winding [the ones attached to the case] resistance is less on 6V than 12V
Bill | | |
