| | | Forums66 Topics128,140 Posts1,056,771 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 614 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 614 | I just reinstalled my new rebuilt head and was connecting the new oil feed line using some of the original brass fittings. I noticed that the fitting coming from the block to supply the oil, only has a small orifice hole. Is this normal or did someone install a different fitting. It would be my opinion that it should be the same diameter at the 1/8" tubing to get plenty of oil up top. Any feedback would be appreciated. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 |
Steve H
| | | | | Joined: Feb 2013 Posts: 614 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 614 | Sorry about that, its a 53 chevy 216. | | |
