11 members (Peggy M, klhansen, Wayne67vert, 52Carl, Hotrod Lincoln, Forty9, walter74, HandyAndy, cmayna, 55shaker, TPR57C),
138
Mod | | | Forums66 Topics128,114 Posts1,056,282 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96195 07/02/2006 1:26 AM | Joined: Apr 2006 Posts: 36 Junior Member | | Junior Member Joined: Apr 2006 Posts: 36 | Wiring a '53 GMC 1/2 12 volt -- The new harness I'm using has no hot/batt connectors for the heater blower switch and the e-flashers. Do I need a terminal block or something like that or should I just connect back to a batt source on the ignition switch or headlamp switch? Also the new heater blower switch has B terminal and an M terminal, assume B is for Batt/hot what is the M for?
John | | |
#96196 07/02/2006 7:18 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You need to get a universal fuse panel. Run a wire from the acessary side of the ign. switch to the fuse panel & short pieces of wire to each circuit you want to use. Than run a wire from each fuse to the acessary you want to power. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#96197 07/02/2006 8:12 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The blower should be powered froom the ignition switch using an inline fuse. I don't know about the "M" terminal.
The Flasher should be powered using an inline fuse. If you don't want them to work with the ignition off than they should be powered from the igintion switch. However, I think the common way is to power them from the constant supply by hooking them up either to the amp meter or the acc terminal of the light switch. Again use an inline fuse. | | |
#96198 07/03/2006 3:11 AM | Joined: Apr 2006 Posts: 36 Junior Member | | Junior Member Joined: Apr 2006 Posts: 36 | Thanks for the input. I do have in-line fuses and would like to avoid a fuse panel. And yes I don't wnat them working unless the ignition is on, so I need to connect both to the IGN post on the ignition switch? | | |
#96199 07/05/2006 9:22 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | John, one side of your ignition switch is live and the other side is switched. You want the switched side. | | |
#96200 07/05/2006 10:21 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Flashers would of course be fused, but would they be switched? Your rig is disabled by the side of the road..you're on your way to the gas station for fuel..do you want the ignition switch on! Just a thought.
Stuart | | |
