3 members (TexasA&M48Truck, Peggy M, 1 invisible), 118 guests, and 3 robots.
Topics128,081
Posts1,055,955
Members48,430
#961555 08/06/2013 4:34 PM
This would be for my 49 Half Ton. Just looking into the best source for a t-5 and wondering what else is involved in making the swap...
Presently have the stock 4 speed Granny trans and also wondering about re-gearing the first three..anybody do that as a cheaper alternative? Likely not worth the trouble and expense..
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
Redryder pix
My Hotrod
Thanks Joker.... there sure is a lot of info there... !!
Mark
1949 Chevy 1/2-Ton
Lucielle
Riding in the Passing Lane
The best place to find one is the pull it yourself salvage yards. If you find one that someone has already pulled the engine it is real easy getting it out. Another place is Craigs list. You can call the full service yards but they are kinda high.
1972 Chevy c10 Cheyenne Super
The pre 88 S10's are the best place to look. 89 on up used an electric speedo. The 93 on up used the Ford style bolt pattern.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
I recommend building a hybrid (V8 camaro front and S-10 rear) or sourcing the rare 1986-1988 Astro van T-5.
then you have the 26 spline input shaft and you do not have to cut splines deeper like you do on the 14 spline units from behind the 2.8
I'm doing this swap now and picked up a T-5 on ebay with mech speedometer (1352-145) for $400 shipped.
Think theres one in the classifieds on the hamb now..
so far I've got the adaptor plate in behind my 216, an 11" clutch from rockauto, and trimmed the bearing retainer and input shaft. clutch fits good with good clearance...
next is final install and get the driveshaft shortened.
Then on to a solution for mounting the e-brake lever...
good luck with your swap lots to learn from the folks here...
Ive never used an adapter but it seems if you do you don't have to cut the retainer or the shaft.
I used an adaptor and had to cut the shaft and retainer.
Pilot bushing depth might make a difference on the shaft and clutch disc choice may make a difference on the retainer. you just need to compare dimensions old & new and adjust accordingly. It's not one size fits all for certain...
