6 members (tclederman, Peggy M, MRMEROTH11, Wickedbass, Barney1951, TUTS 59), 78 guests, and 1 robot.
Topics128,068
Posts1,055,880
Members48,428
#96191 07/01/2006 7:10 PM
Junior Member
Junior Member
Rewiring phase of the '53 GMC 1/2 ton 12 volt. The headlamp switch does not have a post for the Stop light wire. It has connectors for head,park,tail,batt,dash and aux. Assume I can connect dome to aux post. Do I need another switch $$ or is there a way to make this work?
#96192 07/01/2006 9:54 PM
Riding in the Passing Lane
The stop light should have it,s own fuse & come off a hot circuit.
1972 Chevy c10 Cheyenne Super
#96193 07/01/2006 10:00 PM
John,
I do not know the configuration of a GMC switch. Below is a picture of many Chevy switches. The stoplight (and dome light) should always be hot, so either the battery lead or any another lead that is always hot would seem like good choices.
Tim
[img]http://home.nycap.rr.com/lederman/images/lightswitch.jpg[/img]
#96194 07/02/2006 1:16 AM
Junior Member
Junior Member
Tim,
Thanks for the reply. Is the Aux hot or the same as Batt(always hot)? I was going to hook the dome up to the aux and I guess I could use the aux or batt to do the same for the stoplight?
