9 members (cmayna, Nick in Manitou, Hanks custodian, RdsLessTaken, homer52, Gdads51, mick53, kurbside bolter, 1 invisible), 79 guests, and 2 robots.
Topics128,264
Posts1,058,355
Members48,485
#961785 08/07/2013 2:43 PM
53 Chev 2 ton COE. Anybody know the easiest or proper way to adjust the door hinges? Typical problem, the door is scraping against the cowl when it opens and closes. The top hinge does not look like the factory service manual says it should. Thanks.
George,
As best I can tell from your photobucket pictures, you have the correct top hinge. Perhaps you could put a better and closer picture on your photobucket for us to see. I think the service manual shows a standard cab, which has a different top hinge than your COE.
Both of the hinge "straps" inside the door have slotted holes. These allow you to adjust the door in the opening. The top hinge is behind the cardboard panel at the top of the door. The bottom hinge is accessed after removing three hole plugs(which is very different than a standard door). These plugs are often missing and you may just have the uncovered access holes. By gently loosening the bolts you can tweak the alignment of the door.
Hope this helps.
By the way, I didn't see you this year at the Watson Lake show!
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
George, Can't remember if I asked you if you plan to keep your truck a dump truck, or convert it back to a Road Tractor? That's a neat lil' truck. I had a '53 5100 Tractor just like it.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
