8 members (Robert Crandall, kades51, Hotrod Lincoln, jay d, Hanks custodian, Rusty Heaps, Uncles51, 1 invisible),
124
Mod | | | Forums66 Topics128,041 Posts1,055,480 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 26 New Guy | | New Guy Joined: Jul 2013 Posts: 26 | The leafs on my front leaf springs do not line up with each like the rears do. Is this by design or is there a broken pin or bracket that is supposed to keep them in line? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If the leaves not being aligned is what you're talking about Gary, this should show you the clips that should be on your springs. http://www.pbase.com/dennygraham/image/122327625Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Denny -
Are the clips riveted to the springs or are they loose? The clips on my '54 with heavy duty rear springs can slide back and forth.
- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | We are talking about the front spring here, and yes the clip is flush riveted on the inside to the leaf. You can see the formed or secondary head on the outside of the clip in the photo.
Also, the rear clips are a riveted to the leaf.
