4 members (Tom McGrath, TexasA&M48Truck, Otto Skorzeny, Gdads51), 97 guests, and 2 robots.
Topics128,094
Posts1,056,051
Members48,433
#956903 07/16/2013 11:44 PM
Does anyone make reproduction 47-50 door window channels? This is the part that holds the seal in the door.
Both are gone from my right door and half of the front on the drivers door is gone.
I'm told the fronts are welded in place while the rears are screwed down; is that right?
I have not seen them reproduced for the 47-50
Try a post in the parts wanted section of the forum
Yes they are screwed in place on the latch side and spot welded in the hindge side.
Thanks DADS50 for the photos!
I don't have either channels in both doors.
Yes, I just ordered a set from chevsofthe40s.com.
I ordered lower glass run front and rear as well as the complete window channel set.
