| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | Does anyone make reproduction 47-50 door window channels? This is the part that holds the seal in the door.
Both are gone from my right door and half of the front on the drivers door is gone.
I'm told the fronts are welded in place while the rears are screwed down; is that right?
Thanks | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I have not seen them reproduced for the 47-50 Try a post in the parts wanted section of the forum Yes they are screwed in place on the latch side and spot welded in the hindge side. | | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | Thanks DADS50 for the photos!
I don't have either channels in both doors. | | | | | Joined: Jul 2013 Posts: 12 New Guy | | New Guy Joined: Jul 2013 Posts: 12 | Yes, I just ordered a set from chevsofthe40s.com. I ordered lower glass run front and rear as well as the complete window channel set. | | |
