5 members (TooMany2count, Otto Skorzeny, MickeyP, Wally / Montana, Bill Hanlon), 101 guests, and 2 robots.
Topics128,052
Posts1,055,729
#959962 07/30/2013 2:59 PM
I have been looking for front lower gas shock mounts to put on my '48 1 ton. I have not had any luck wih Jim Carter or the othersupplies, and no hits in a parts wanted ad.
Is there someple else that you know carries them?
Has anyone every tried to splice the 1/2 ton gas spring mount with the 1 ton lever action mount?
I have a 41 1 Ton with lever action shocks. Why bother? The springs are so stiff what good would it do.
If I really needed a change I would splice in a new IFS set up and go with power steering as well.
Redlegs48 #960076 07/30/2013 10:45 PM
The cost for me to get my lever action shocks going is equivalent to putting in gas springs, and it is something I can pull off in a weekend. Springs have lost a little bit of their stiffness over the years and they could benefit from a little damping.
Front lower, the ones that bolt under the front spring U-bolts?
A picture might help your wanted ad?
I figured they'd be common enough used..
1952 Chevrolet 3800 pickup
---All pictures---
Redlegs48 #960359 07/31/2013 10:19 PM
Maybe a machine shop/welding shop could fab something for you. Make a template out of poster board and take it in.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Since I had bought the 1/2 ton mounts before I realized they would not fit... I went for the method that involved splicing the two mounts together.
It was a fairly simple process;
- I took a whiz wheel and cut off the far mounting hole on the purchased mount
- Put the original bracket on the u-bolt then put the not cut bracket on top of it, then I marked the location to cut on the original bracket
- Cut original bracket and grind so both cut faces contact cleanly/ grind "V" to help in welding
- Clamp to a flat surface and weld
- Grind away some material for clearance on the axle. (There is a raised portion that I don't think is on a 1/2 ton)
Mount Modification
Moderated by  Dusty53
