7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 54 | Hi - I'm just trying to get my heater back on line. I have a 37 gmc 1/2 ton. The heater in it has eaton stamped on the back and no other markers - it's a three door model with two doors that open sideways and a bottom door that opens up. My questions: Could this possibly be the dealer installed heater? I know chevy trucks had badging on their heater. What have people used to repaint the heater fins?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | in Canada I'd suspect that's an aftermarket item from a well known defunct department store the cheaper dealer installed heater would more commonly have had a GM logo rather than Chev, and would have been made by Harrison .... you'd use a high temp flat black paint on the core, same as a radiator, but as it's hidden and likely copper, the best thing would be to just clean it up and leave it unpainted Bill | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | doesn't look GM truck to me, too square, and the controls I've seen from then were paddle switches
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'd say it's aftermarket but that's not to say it's not 'correct' for the truck. A large percentage of trucks in that era had aftermarket heaters. I imagine they were a lot cheaper than a dealer installed one. | | |
