| | | Forums66 Topics128,154 Posts1,056,856 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | I'm grinding down the frame under my bed and wondering how to attack those corners and areas that I can't get the grinder, wire wheel or Dremel tool into. I tried Naval Jelly to see if it really did anything and it might have accelerated the de-rusting with a stripping pad but wonder if there is something better.
Appreciate anyone's thoughts. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Naval Jelly is Phosphoric Acid, chemically changing the iron oxide (rust) to iron phosphate - available in many forms and in many products - it's more a rust converter than a rust remover, once the rust has been turned black you can carry on with the paint, providing you're not trying to get a mirror finish for a show machine, only other way is to mechanically abrade the piece [grind, sand, chip] down to clean steel, in some places an air chisel might work Bill | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I've used it to remove rust from sheet metal. Seems to work beest by brushing it on, let stand 5-10 minutes then taking a piece of steel wool and working it around on the metal. Then wash off and dry....
John | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 |
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | I wish I saw this before I did most of my frame with a wire brush and dremel tool...... | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | Paint stores carry phosphoric acid which is main ingredient in Naval Jelly which is diluted 3 to 5 times to keep the off gassed acid vapors tolerable.
Phosphoric will work much faster than Naval Jelly. DO NOT get it in your eyes. Wear chemical safe goggles.
If you use phosphoric you will want to be in open air and with a fan. If in garage you will not only need but WANT a respirator with acid gas cartridge.
Dan Bentler | | |
