| | | Forums66 Topics128,154 Posts1,056,837 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 443 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 443 | Bolters,
I'm looking to migrate from 6V to 12V. Can anyone provide a NAPA or equivalent coil to use with my existing distributor. Also, is it safe to assume I can use the same condenser?
Truck: 1947 AD, 216, 1-ton dual wheel
Thanks in advance.
Joe 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | If you are looking to purchase a 12-volt coil with the internal resistor which is what I use with my 235 I bought one of these. Their description should let you find a similar NAPA or FLAPS equivalent.
Jim Carter EL-158 this type of coil was on use in many applications until 1976 when HEI coils became common. | | |
