3 members (Hotrod Lincoln, 2-Ton, MikeE), 133 guests, and 3 robots.
Topics128,266
Posts1,058,385
Members48,485
Could somebody look in their parts book and see if they can find the GM part number 3771216? It's a tachometer and is supposed to be for a 61 or 62 C10. It looks like the same tach for 64-66 trucks. If it would fit my 66, does it need a transmitter?
Thanks!
X
X Offline
I don't know anything about these tachs, but I'll give you what my parts books show.
3171216 is listed as the head assembly for '61-'62 series 10 thru 30 (no distinction between 6- or 8-cylinder). The numbers are 3852111 for '64-'66 series 10 thru 30 6-cyl, or 3839947 for '63-'66 series 10 thru 30 8-cyl. units. A transmitter is only listed for the '61-'62 8-cyl. units.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
Thanks Curt, that makes perfect sense.
Since the tach in question apparently needs a transmitter, that's why it's only listed for the 60-61 trucks. I'll need to look for the 8 cylinder part number for my 66 so I won't have to worry about needing a transmitter.
Thanks!
Larry
