1 members (dt235sd),
101
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96012 06/18/2006 6:19 PM | Joined: Apr 2006 Posts: 14 New Guy | | New Guy Joined: Apr 2006 Posts: 14 | Could somebody look in their parts book and see if they can find the GM part number 3771216? It's a tachometer and is supposed to be for a 61 or 62 C10. It looks like the same tach for 64-66 trucks. If it would fit my 66, does it need a transmitter?
Thanks! | | |
#96013 06/19/2006 8:40 AM | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | I don't know anything about these tachs, but I'll give you what my parts books show.
3171216 is listed as the head assembly for '61-'62 series 10 thru 30 (no distinction between 6- or 8-cylinder). The numbers are 3852111 for '64-'66 series 10 thru 30 6-cyl, or 3839947 for '63-'66 series 10 thru 30 8-cyl. units. A transmitter is only listed for the '61-'62 8-cyl. units.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
#96014 06/19/2006 11:53 PM | Joined: Apr 2006 Posts: 14 New Guy | | New Guy Joined: Apr 2006 Posts: 14 | Thanks Curt, that makes perfect sense.
Since the tach in question apparently needs a transmitter, that's why it's only listed for the 60-61 trucks. I'll need to look for the 8 cylinder part number for my 66 so I won't have to worry about needing a transmitter.
Thanks!
Larry | | |
