8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian),
149
Mod | | | Forums66 Topics128,043 Posts1,055,524 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95979 06/17/2006 5:04 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I need some help on splicing stranded wire together. I plan on soldering the stranded wire together then using heat shrink tube around it. The question is on stranded wire is it best to separate the wires and mesh them together before soldering them? Is rosin core solder recommended?
I appreciate any assistance. | | |
#95980 06/17/2006 5:32 PM | Joined: Jul 2005 Posts: 17 Apprentice | | Apprentice Joined: Jul 2005 Posts: 17 | I don't go to the trouble of braiding lots of tiny filaments. I kind of flatten the wires out, lay them on top of each other and twist.
The stripped ends need to be long enough that you can twist and they lock together. That way the connection has some mechanical integrity. Then solder them. I use a mini-butane torch for 14 gauge and up. Heavy wires will suck all the heat right out of a lightweight soldering iron tip. The tip must have more mass than what you're soldering. I use rosin-core electronic solder for everything, the kind you can buy on spools from Radio Shack or any electronics supplier. | | |
#95981 06/17/2006 7:46 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The joint should be done as described, with electronic solder. A soldering gun provides a lot of heat when needed. | | |
#95982 06/17/2006 8:51 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I prefer marine quality crimp splices with heat shrink sleaving. These are less prone to breaking due to vibration, as both the conductor and the insullation are restrained. Solder will migrate up the wire and can cause the wire itself to fail over time. Of course, most of the splicing I did was on ocean going boats, a harsher environment than most Bolts ever see. | | |
#95983 06/17/2006 9:05 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I like rosin core solder because the rosin is an etching agent and keeps the solder on the wires.
I flatten things out, tin the ends, and then solder them together, just like my daddy taught me.
And yes, I use heat shrink tubing. I noticed that they have a bunch of pretty colors today at my FLAPS. | | |
#95984 06/17/2006 9:07 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I use that type connector as well, namely because I can't solder for spit. If it's something that needs to be able to disconnected I also use Posi-Locks with the wheather protection boots. I get most of my connectors and wire from the local farm store and Menard's, you'ld be suprized at what you can find in those places.
Bill Burmeister | | |
#95985 06/18/2006 12:20 AM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | I use tinned uninsulated crimp connectors to connect the wires together, then solder, then heat shrink. The crimp connector gives the connection some mechanical integrity and makes it easier to solder. Always use rosin core solder. | | |
#95986 06/18/2006 12:43 AM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
#95987 06/18/2006 1:11 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a soldering tip -> have a good mechanical connection before making the electrical connection [solder] 1 - strip each wire about the same amount - don't nick any strands 2 - twist the ends together well 3 - when the iron is hot , "tin" the iron with a small amount of 60/40 resin core solder - do NOT use acid core [radiator] solder 4 - put the wires on the iron , and apply the solder to the wire - stop as soon as solder flows over the full length of bare wire 5 - when the joint cools , bend the joint flat against one wire last, slip the heat shrink tubing over the joint and shrink it [you did remember to slide a piece on before joining the wires?] soldering is always preferable to crimp connectors, which might make a good mechanical connection, but frequently don't make a good electrical connection, at least not one that lasts Bill | | |
#95988 06/20/2006 12:34 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | a proper ''western union'' splice or staggered WU splice (two + wires) http://www.tpub.com/content/neets/14176/css/14176_46.htm is to bring the stripped wire butts 1/2 way together and wrap each side round the other. solder. tape i now use heat shrink it works for solid and stranded, got it's name from . . . . you guessed it right the railroad telegraph, 1861 Western Union completes the first transcontinental telegraph line, providing fast communications during the Civil War. more insane railroad trivia SPRINT stands for S outhern P acific R ailroad I ntigrated N etwork T elecommunications
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#95989 06/20/2006 5:43 AM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | In past years I would and still do solder wiring. My shop teacher in high school tought me to use what is called a (western union splice) Its simple to do but difficult to describe without a picture. Maybe you can look it up on the web. Oh and I use heat shrink. I found heat shrink not only in all colors but also in any length and diam. you want at an electrical supply.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
#95990 06/20/2006 8:48 AM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Tiny...wish I could take credit...I learned it from madelectrical.com. Some good stuff on there. | | |
