8 members (3B, Phak1, 1955 1 Series, Peggy M, 55shaker, TUTS 59, WICruiser, Gray_Ghost),
132
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,105 Posts1,056,552 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95960 06/16/2006 2:29 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Hello all, Should the gas tank sending unit be grounded to the cab or to the chassis?
Thanks Billy | | |
#95961 06/16/2006 2:59 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | both/all ground it to the tank thru one of the sender's 5 mounting bolts. from there ground it to the cab or take the wire down that same gas line hole and ground it to the frame. somewhere the cab is/should be grounded to the frame.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#95962 06/16/2006 3:08 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | As Jim said, it should already be grounded. If your tank grounds are iffy (due to rust, corrosion, or other) then you can bring a wire down from one of the mounting bolts and ground it straight to the frame that way. I need to rewire mine (The wire is bad -- and to add insult to injury -- bare in places! Half the time there's no gas or a full tank!) and I'm thinking about grounding it to the frame with a seperate wire just to be sure. But, then again, I'm anal retentive about that sort of thing.  | | |
#95963 06/16/2006 6:23 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Thanks guys,
One more question, What are the style of mounting screw that are used in the sending unit? My 59 has the hour glass shaped instead of a Phillips or flathead. The same kind that are used to mount the cowl vent.
Can you buy this type of bit at a parts store? | | |
#95964 06/16/2006 6:27 PM | Joined: Jul 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 50 | Chevy Duty sells the driver with the hour shaped head.
1951 Chevy 3100 w/235
#95965 06/16/2006 6:57 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | I just found them on the internet. "Clutch head drivers" | | |
#95966 06/16/2006 7:26 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | 10x32x1/2'' or 5/8'' if memory serves me today ground to the top of one of those run another ground to the cab /frame from that point don't trust the gas tank just sitting in the cab's cradle to be a good ground
get rid of the clutch head screws. some like them and they have/serve a purpose, for restoration. they can work just fine but for me that means carring 4 more screwdrivers in my limited tool box...... naugh my .02
#95967 07/31/2006 2:35 PM | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | www.mcmastercarr.com sells clutch head bits and screws. Delivery has been very quick in my experience. 3577 pages of hardware and shop related stuff.
Jim
Good luck with your project!
#95969 08/01/2006 1:35 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Originally posted by TooMany2count: Originally posted by carolines truck: [b]get rid of the clutch head screws i HATE those things, but believe it or not i have seen folks who buy them for restoration projects. why on God's green earth they ever made those things is beyond me. the person who invented them should be shot....joe [/b]Same reason they have Torx,E-Torx,Torx+, and all of thoce other gawd-awfull fasteners with funny heads, they don't want the average guy/gal or non-dealer mechanic to be able to work on them.
Bill Burmeister | | |
#95970 08/01/2006 3:04 AM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Another THANKS to fellow Stovebolters !!
My project for this week was to remove and check the gas gauge / float mechanism. After a total rewire with a made from scratch harness it was the last of the dash items that didn’t work. After reading this I started thinking that when I had removed the tank and cleaned around it there was no sign of any ground wire. And…guess what ?? I missed that little ground symbol on the wiring diagram. So I went right out into the 98 degree garage and installed a temporary ground now even my gas gauge works!! Thanks again | | |
#95971 08/18/2006 8:35 PM | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | I went to the ultimate extreme when grounding my sending unit. At NAPA they sell a two conductor wire encased in a gray outer covering. The red wire is my sender wire and the black is the ground wire which I hooked to the back of my gauge cluster. My gauge used to show having more gas than I actually had, causing me to run out of gas when the gauge showed a quarter tank. I wanted to eliminate this problem so I have the sending unit grounded to the actual gauge cluster. | | |
