| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95930 06/14/2006 3:08 PM | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I'm installing a wiring harness I bought several years back, but there's no connectors for the brake light switch. Can someone tell me what these connectors are called? Are they readily available at a NAPA, etc? | | |
#95931 06/14/2006 5:03 PM | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | What type of connection is on the switch? Mine is an inline switch and it used bullet connectors. | | |
#95932 06/14/2006 7:24 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Older GM trucks generally use the bullet style connectors for the brake switch, usually the small type. NAPA should have them, as would most farm supply and home improvement stores.
Bill Burmeister | | |
#95933 06/14/2006 9:29 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#95934 06/15/2006 8:07 PM | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Thanks, folks. It is indeed the bullet type, and I got a small container of them at Advance Auto. | | |
