8 members (Donf, Gdads51, 55shaker, FAST55, Ponchogl, Wickedbass, Cosmo, Hanks custodian), 66 guests, and 5 robots.
Topics128,065
Posts1,055,868
Members48,428
#95930 06/14/2006 3:08 PM
I'm installing a wiring harness I bought several years back, but there's no connectors for the brake light switch. Can someone tell me what these connectors are called? Are they readily available at a NAPA, etc?
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
What type of connection is on the switch? Mine is an inline switch and it used bullet connectors.
Older GM trucks generally use the bullet style connectors for the brake switch, usually the small type. NAPA should have them, as would most farm supply and home improvement stores.
Bill Burmeister
Jim & Caroline
Thanks, folks. It is indeed the bullet type, and I got a small container of them at Advance Auto.
1948 Chevy 1/2-Ton
