2 members (carbking, RLB),
157
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 23 New Guy | | New Guy Joined: Oct 2012 Posts: 23 | i was doing some reading about up-stroking a 261 using 292 rods and cadillac 368 pistons. Im thinking about doing this to my 261, it has a 848 (235) head. i need to figure out what kind of performance this would get me with a t-5 transmision and a proper rear end ratio. the vehicle is a 59 1/2 ton here is the link where i read about this, let me know what yah think: http://www.angelfire.com/nv/conv/stovebolt.html | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Reading it, it sounds doable.... Just takes money...LOL I wonder how much the breathing can be improved on a 235/261 head? I notice they recommend using the stock 261 head, yet on over it says you can have the top of the block machined so the piston comes closer to the top and raises the compression. I thought that was why they put 235 heads on 261s??
John | | | | | Joined: Oct 2012 Posts: 23 New Guy | | New Guy Joined: Oct 2012 Posts: 23 | i don't think he recomended using the 261 head, it was an alternitave to finding a 848 head. my question is would the engine be happy over all with with a longer stroke, and how it would affect the top speed since it limits the rpms | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | It is doable. Tom Langdon built 1 or 2 of these that I think he sold. If you aren't aware he is a retired GM engine design engineer and did all the research necessary for the Cadillac 261. Expensive? Likely.
Drew
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | With more power you could always upgrade the tranny to a 700R4 automatic or a 5 speed with overdrive in top gear and something like a 3:90 rear end
John | | |
