7 members (Goach2, Dave1234, IHPWR, Hotrod Lincoln, TUTS 59, Peggy M, 1 invisible),
73
Mod | | | Forums66 Topics128,206 Posts1,057,440 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 26 | I have looked at the block ID pages and can't find anything that matches the information stamped on my block. The. Stamp shows: GCA 281766. The head stamp is 3835499. If anyone has a suggestion as to where I should look I would appreciate it.
Thanks in advance.
Wreckin' Ball
I'm gonna need a bigger hammer!!!
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Is the block number punched on a flat surface or is it a casting number? Same with the head which sounds like a casting number. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | A quick search of casting numbers for the head got me as far as 3835497 which is a 216 c.i. head. I am sure someone else will have more for you. | | | | | Joined: Dec 2012 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 26 | Sedgewick,
First off thanks for helping! The block number is stamped in a flat surface on the block. The head number is a casting in the head itself. I can't find the correct head casting number either. I found the same number that you did listed in several places but mine ends with 99 not 97. Just trying to figure out what motor I have in it before I start ordering parts.
Thanks again.
Wreckin' Ball
| | | | | Joined: Dec 2012 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 26 | tclederman, Thanks for the help and advice.
I ran the VIN number when I first looked at the truck before I purchased it. I was assembled in April 1949 in Kansas City. I wondering why it would have a 1949 block and a 1950 head. I'm assuming that at some point someone switched the heads.
So, regardless of the year of the block and head your thinking it's a 216 engine?
That's really what I was looking for. I wanted to know what size I was dealing with and what to expect if I need to do any major work on it.
Are there any other suggestions that you might have for me with this engine?
I recently got it running and it sounds good. No knocks or ticks. Carb is leaking a small amount and I want to rebuild it. Of course I am going to change all of the fluids and replace the points and probably the spark plug wires.
thanks again for your help.
Wreckin' Ball
