9 members (JoergK., Bill Hanlon, J Lucas, Chip O, dt235sd, Gdads51, Hotrod Lincoln, 2 invisible), 75 guests, and 0 robots.
Topics128,205
Posts1,057,427
Members48,471
I have looked at the block ID pages and can't find anything that matches the information stamped on my block. The. Stamp shows: GCA 281766. The head stamp is 3835499. If anyone has a suggestion as to where I should look I would appreciate it.
Thanks in advance.
Wreckin' Ball
I'm gonna need a bigger hammer!!!
Is the block number punched on a flat surface or is it a casting number? Same with the head which sounds like a casting number.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
A quick search of casting numbers for the head got me as far as 3835497 which is a 216 c.i. head. I am sure someone else will have more for you.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Sedgewick,
First off thanks for helping! The block number is stamped in a flat surface on the block. The head number is a casting in the head itself. I can't find the correct head casting number either. I found the same number that you did listed in several places but mine ends with 99 not 97. Just trying to figure out what motor I have in it before I start ordering parts.
Thanks again.
Wreckin' Ball
GCA is the enine serial number preface for a 1949 4000 series truck 216 engine
I found 3835499 as a 1950 head casting code.
Here are locations of head and block casting codes, including date casting codes. Post what you find.
http://www.1954advance-design.com/Web%20images/casting-code-photos/low-press-codes-ser-nums.html
tclederman, Thanks for the help and advice.
I ran the VIN number when I first looked at the truck before I purchased it. I was assembled in April 1949 in Kansas City. I wondering why it would have a 1949 block and a 1950 head. I'm assuming that at some point someone switched the heads.
So, regardless of the year of the block and head your thinking it's a 216 engine?
That's really what I was looking for. I wanted to know what size I was dealing with and what to expect if I need to do any major work on it.
Are there any other suggestions that you might have for me with this engine?
I recently got it running and it sounds good. No knocks or ticks. Carb is leaking a small amount and I want to rebuild it. Of course I am going to change all of the fluids and replace the points and probably the spark plug wires.
thanks again for your help.
Wreckin' Ball
