1 members (78buckshot),
64
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95911 06/12/2006 1:35 AM | Joined: Jun 2006 Posts: 24 New Guy | | New Guy Joined: Jun 2006 Posts: 24 | I just put a battery in my 51, first time powere has been in it in over 25 years. I got my gauges moveing, running lights, no head lights but after the fact I looked at those wires and found them needing replacement. I did all this to see if the motor would even turn over, however I got nothing out of the starter.
My question is, What are the steeps need to rebuild the starter, or can that evevn be done? | | |
#95912 06/12/2006 2:12 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | First I would pull the starter and attach it to a good battery and see if it spins without being in the car. You will have to manually operate the foot switch. You did try to turn the engine over by hand, right? | | |
#95913 06/12/2006 2:13 AM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Sure it can be rebuilt but first remove the starter switch from the top of the starter. Make sure the contacts aren't dirty or burnt to the point of not making contact. Also pull the spark plugs and try to turn the engine over manually to rule out the possibility of a frozen engine. Another step is to check the ground strap from the battery to make sure it's clean on both ends. Good luck.
#95914 06/15/2006 4:58 AM | Joined: Jun 2006 Posts: 24 New Guy | | New Guy Joined: Jun 2006 Posts: 24 | Alright i got the starter out, and the switch on top off. It looks likr the little brass plates inside are fairly worn. I also was ablr to turn the motor over, which i'm very happy about. now my question is where might i be able to find a new switch for the starter, or would it better if I were just to buy a new starter?
Getting closer to get this bolt rolling!!! | | |
#95915 06/15/2006 11:45 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Is this the part you are referring to? It is available from most vendors. NAPA and Advance Auto and maybe AutoZone. | | |
#95916 06/16/2006 2:59 AM | Joined: Jun 2006 Posts: 24 New Guy | | New Guy Joined: Jun 2006 Posts: 24 | great, thanks TC, i'll head over to NAPA tomorrow. | | |
#95917 06/16/2006 4:46 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | They sell regularly on eBay for around $10. Good Luck.
#95918 06/20/2006 12:25 AM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | On a motor that has been setting for 25 years could have some stuck valves. Might be a good idea to pop the tappit cover off and check the valve train for movement while turning over slowly by hand, also you probly have a tank full of bad gas. | | |
#95919 06/21/2006 10:59 PM | Joined: Jun 2006 Posts: 24 New Guy | | New Guy Joined: Jun 2006 Posts: 24 | 10-4 Todd, my brother told me the same thing, and it's good that he has the experience on the 235. I was supprised that there was still "fluid" in the carb when i took it off, so that told me that the tank has got to be the same way, I dont think they had 'Stabil' back then, so that's going to be my next step after I get the wiring down.
once again thanks the help all! | | |
#95920 06/21/2006 11:41 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Definitely drain your gas out of the tank. It's going to be the most foul, rotten stuff you'll ever smell, and it won't work in your engine. If you need to start a bonfire, on the other hand... Clean the carb, and rebuild it. You'll be glad you did. And strictly speaking, you don't need a starter so long as you you have your arms and a crank.  | | |
#95921 06/22/2006 12:36 AM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Originally posted by Brendan M: Definitely drain your gas out of the tank. It's going to be the most foul, rotten stuff you'll ever smell, and it won't work in your engine. If you need to start a bonfire, on the other hand... The stuff I drained out of the 38 after it sat in the tank for over 20 years smelled like the devil's armpit. I used it to kill grass in the driveway & the whole property smelled like that for a week.
