2 members (Stewart2, Hanks custodian), 96 guests, and 8 robots.
Topics128,014
Posts1,055,324
Members48,419
#958848 07/25/2013 9:17 AM
awk
Offline
Hi,
I'm new to Stovebolt. I have a 54 Chevy 3100, 235, which has the add on filter near the carb. My question is when changing oil, the 235 takes 5 quarts, do you add 1 quart for the filter? 6 quarts for an oil and filter change.
Thanks a bunch,
awk
awk #958874 07/25/2013 12:43 PM
Welcome to Stovebolt.com, awk,
If you have a 1 qt canister by-pass oil filter, and you change the filter-element and remove all the old oil from the canister, you would an extra quart of oil when you change oil.
5 qts for the engine
1 qt for the 1 qt filter unit
Some people put some oil in the filter canister when they change oil/filter. This results in less delay in the oil feed/pressure when starting the engine after the oil change.
awk #958996 07/25/2013 10:07 PM
Good information to know.... John
